6.0 Lq9????
6.098, is the stock length for them. 6.125 is a common after market rod for small block chevy's that is also used in these motor, but you have to use the right pistons for them also.
Originally Posted by BaD406
my donor lq4 is from year 2000 does anyone know what length rod i have ??? 6.098 or 6.125??thanks in advance!!
Yes it will be balanced!! somebody said i need to replace reluctor anytime you remove the crank?? Is this true?? i thought u didn't have to as long as you didn't ding or hurt reluctor!!
Originally Posted by Yogi Bear
Yes, you can use the LQ9 pistons. Early LQ9's also had stronger rods, too. Later LQ4's and LQ9's use the same rods. Be sure to upgrade you rod bolts while you're in there.
