6.0 deal need an answer quick
Old Oct 25, 2013 | 10:15 AM
tim wellington's Avatar
Default 6.0 deal need an answer quick
got a chance to buy 6.0 1999 steel head motor .other than steel heads are blocks and internals the same?some one please
Old Oct 25, 2013 | 10:27 AM
Vortec350ss's Avatar
The LQ4 had some internal upgrades made late in 2004 for the 2005 model year. The only other difference I believe is in the length of the crank on the back of the engine. The earlier model LQ4 will only work with an 80e, where as the newer ones (forget exactly which year) switched so that they could be used with a 60e in a half ton.
My guess is the 1999 and 2000 are this way, and it was updated in 2001 when the LQ4 became available in the Denali half ton trucks and SUV's.
Old Oct 25, 2013 | 10:30 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Longer crank will only work with an 80e, as already stated. Don't pay very much for it IMO.
Old Oct 25, 2013 | 10:52 AM
Default $$$
250$ good?
Old Oct 25, 2013 | 10:55 AM
$100-150 imho.
Old Oct 25, 2013 | 11:38 AM
Default thanks
thanks
Old Oct 26, 2013 | 07:06 PM
Noah Burns's Avatar
the block alone is worth every bit of $300-400 so no reason to think it's a bad deal if you get it any cheaper than that.
Old Oct 28, 2013 | 10:47 AM
Gadgetized's Avatar
When I did my 370 I got a 99 6.0. As stated above, the crank is longer by about .400". I ended up going with an aftermarket crank so it didnt matter much in the end. I do have to agree that the blocks are worth 3-400. If you can get it for $250 I would say to grab it. Just remember you need to get heads too. Around here 6.0's seem to cost much more.
Old Nov 15, 2013 | 02:16 AM
PonyJender's Avatar
Banned
Old Nov 15, 2013 | 07:11 AM
Koots's Avatar
I recently picked up a 2007 4.8L with a ticking lifter for $200, so you can find good deals out there. The engine looks brand new, but I haven't checked the lifter yet, but the like-new intake gaskets were worth half the price by itself, let alone the 243 heads and intake manifold.
Knightcrawler
Jul 20, 2016 03:29 PM
murderedSS
27
Oct 12, 2015 11:13 AM
custm2500
Sep 8, 2015 05:53 PM
chvy=power
Sep 8, 2015 11:06 AM
mr03silverado
Sep 2, 2015 11:43 PM
