500 plus lq4?
MrhorsepowerLSX is right about reliability and water being an issue. If you could protect it well I would say the cheapest route could be found here
https://sites.google.com/site/sloppy...unkyardturbols
I guess it depends on your budget, if your going to cover it in water often, what its primary use is.
There's No replacement for displacement, plus mud + Turbo/blower equals bad news and wasted money, no matter how well protected it is, mud always finds ways into interesting places. I'm not a fan on N20 but that would be your most reliable power added as it is "sealed" from the elements. And probably cheapest too
Don't forget that you need to protect the airfilter, and what happens when the airfilter gets wet. Just saying........
Even if he runs a PD/Centri blower, as soon as that belt gets wet/muddy it is going to start slipping anyways, unless it is cog driven. But with that said,
I have seen a few setups where bed mounted tool boxes were converted into housing a turbo charger which was totally sealed and water tight, I have also seen same theory applied for air intake filters, kinda like a giant snorkel box. But if he plans to install as stock setup, money is just being flushed down the toilet
Would hope on a true mud truck it has some kind of snorkel setup anyway.... The occasional mudhole/trailriding truck can typically get away without one keeping in mind that the engine compartent at steady speeds through high water will actually stay somewhat dry, its when you stop you get screwed....
