5.3L swap to 6.0L cam ?
Old Jul 17, 2016 | 09:09 PM
LARRY01Z28's Avatar
Default 5.3L swap to 6.0L cam ?
Ok I have a 2005 Silverado crew cab with a 5.3L, LT 1 7/8 headers, U/D pulley, CAI, Magnaflow exhaust, 2600 stall, 4:11 gears, built 4l60e, 212 218 low lift comp cam. sprins, CM pushrods.
Ive come across a LQ4 (I swapped in a new motor for it) for free and I'm turning it into a LQ9. I was wondering if I should use the BTR stage 3 truck cam or the BTR stage 4 truck cam. thanks for any help.
Old Jul 18, 2016 | 06:47 AM
madmann26's Avatar
Depends on your goals. With the 4.11 and the small stall, the stage 3 cam would be fun.
For the stage 4, you would want a stall of around 3000-3500 for it perform as expected.
The stage 4 as that "popcorn" sound that some people like. There are a few youtube videos of trucks with the stage 4 and it sounds mean.
https://www.youtube.com/results?sear...+truck+stage+4
Old Aug 2, 2016 | 09:24 PM
LARRY01Z28's Avatar
yes that stage 4 cam sounds great. I just kind of want a good cam for the 6.0l, 2600 stall and 4:11 gears.
Old Aug 3, 2016 | 06:37 AM
madmann26's Avatar
What are you looking for? Low/mid power, mid/top power?
With a 2600 stall that stage 4 will feel kinda bleh on the low end. The stage 3 would work good and it would be torque happy off-idle.
Old Jan 25, 2017 | 09:17 PM
LARRY01Z28's Avatar
that's what I want is the low end and just an overall faster truck. I tow with it about once a month. a 14 foot trailer with a 1250lb side by side.
Old Sep 9, 2017 | 11:30 AM
squirrels 06's Avatar
Do you know what you're putting to the wheels or have you ran it at the track?....the 5.3
El_Diablo
Jan 4, 2017 08:29 PM
trxmxzx
Mar 6, 2016 07:55 PM
jiar577
Feb 29, 2016 10:47 PM
dcs191919
Feb 22, 2016 06:32 PM
99RedHawk
31
Jan 29, 2003 06:30 PM
