5.3l and 4.8 block question?
Old Feb 10, 2008 | 03:04 AM
mike06tork's Avatar
Default 5.3l and 4.8 block question?
is the 5.3 block and the 4.8L. block is the same block can i put in a 5.3 crank in the 4.8 block and bore it out to a 347 with 3.905 bore with forged pistons for FI and will work fine with no problems. And is the wheel in the back of the crank with the same part number is the same as all the cranks with the same part numbers it will have the same teeth on them.
Old Feb 10, 2008 | 05:17 PM
mike06tork's Avatar
anybody knows
Old Feb 10, 2008 | 06:16 PM
jkwalkercchs's Avatar
yes u can put 5.3 intenals in a 4.8 block
Old Feb 10, 2008 | 06:34 PM
mike06tork's Avatar
but can i bore out he 4.8 block to a 5.7 with 3.905 Mahle pistons is it possible and with no problems with the block still having enough metal in the bores for FI engine turbocharged.
Old Feb 10, 2008 | 06:50 PM
its been done
have it sonic tested
Old Feb 10, 2008 | 09:04 PM
kbracing96's Avatar
5.3 and 4.8 are the same block.
Old Feb 11, 2008 | 11:06 AM
Formula96's Avatar
same bore differant stroke, and the 4.8 block is cast iron, 5.3 block is aluminum
Old Feb 11, 2008 | 11:17 AM
kbracing96's Avatar
Only the new 5.3 L33 blocks are aluminum. The Iron blocks from 99 to present are identical and cast with 4.8/5.3 on them.
Old Feb 11, 2008 | 11:25 AM
Formula96's Avatar
my bad
Old Feb 11, 2008 | 12:03 PM
mike06tork's Avatar
So I Can Bore It Out To A 5.7 The 4.8 Block Right It The Same Block It Will Be The Same .
