5.3 head milling
11 Second Truck Club
I just wanted to know what some of you guys have milled your stock 5.3 heads too on a 5.3, and what compression ratio it neted you. .030" is the standard, and I have found some that have went out to .050". calculators give me different answers. looking to get to 10.5:1. I know 11:1 is doable, and have seen 228/230 cams with a .050 mill. just wanted to see what you guys have done. ptv clearance issues anyone?
thanks
thanks
I had the same question, If i could get to 53cc with a .041 head gasket i think i'd be right around 10.7-75:1 But i Don't know what my factory piston dish is or how far they are in the hole from the factory, and then What kind of lift can i expect to use after milling? Hope i'm not hi jacking i was just curious my self, Thanks
I had a hard time finding exact answers to those same problems. I came up with a dish of -8cc on one calculator. and a compressions ratio and mill calculator came up with a .036 mill for 10.5-1, and .049 for 11-1. and -.008 out of the hole, but some say -.006. the only sure way to get it is to measure for yourself.
wow our setups are way different. you got enough mph for 12.9's 60 ft is your killer. good times though. I am still not sure on how much to mill, looking at different cam choices and how much spray I want to run(just put the kit on).
i've personally got my stock heads .045 and running the 228/228 588 588 112 but hopeing to get rid of it soon (cam)...i also have a friend who actually has a pair of 862's milled .050 best he's hit was an 11.3..... i myself changed pushrods from the 7.4's to the 7.350... and did not have any pvt issues...im running the TBSS intake with the ls2 90mm TB.
