5.3 to 6.0 mods + turbo
#42
Ok, here is what i am going to do.
the engine that was listed in my first post
LSX intake with 90tb
STS turbo with GT 70 and meth. inject.
4L80e built
4.10 rear (forgot the brand, i will look it up and post it later.)
A couple of other things such as the boost control, elec. fans, wires, msd blast coils, etc. etc....
One thing i forgot was what fuel system to go with, what upgrade should i do, what injectors and should i upgrade the fuel pump or will the stock work.
4L80e built
#43
maybe you have looked at it already, but have you considered the livernois turbo kit?
i'm pretty sure you need upgraded fuel pump and injectors, but i dont know what ones. take a look at parish's setup. i think he did it through racetronix. alotta people say to get stock gears because they are quieter. is the built 80 from flp?
#44
4L80e built
4L80e built
Philip S.
#45
here is my list so far, i am sure i have left something out.
The motor (listed on first post) $14,700
to many gauges haha ???
Squires Turbo System for Chevy/GMC $7200+-
intercoller kit
blow off valve
methanol injector
GT76 turbo
Duel stage boost control
Granatelli Calibrated Mass Airflow Sensor $339.95
MSD LS-1/LS-6 Blaster Coil $79.95 X 8
Nology Hotwires Power Package $196.95
Denso Iridium Spark Plugs $11.99 X 8
Hypertech Low Temperature Thermostat $50
SuperMaxx Exhaust Systems $1300
LSX intake with 90mm tb 1000+-
built 4l80e tranny with lower first gear. ???
YANK SC 3000 converter $989.99
Flex-a-light elec. fans $400
Trans. cooler $50
built Currie Gm 12 bolt rear with 4.10 with new drive shafts ???
If you can think of something else i need, or something to change please let me know.
intercoller kit
blow off valve
methanol injector
GT76 turbo
Trans. cooler $50
#46
i dunno if the 160 or 180* thermostat is a good idea...theres conflicting opinions on their usefulness. lots of posts on that topic i think
i have never heard of anyone doing the nology wires. i had it pegged as a gimmick, but hey, when youre doing a high dollar setup like this, why not?
i've heard granatelli's are a gimmick too, but i dont know from experience.
another thing that you could reconsider is the motor and how much strength you need vs. how much you want to spend. you could go with brands like eagle instead of lunati and callies and save a shiteload of money, but if you are willing to spend the money, then you should spring for the best.
sounds like an awesome setup. this is what alotta people on this board dream about at night, and actually being able to put this in your truck is awesome. best of luck with it
#47
The list that we have is close to what we are getting, all this will happen. It is me and one other guys doing this project, and with our payrolls combined we will have all the money plus some in a little under 3months. So we have set a dead line of a year to complete this. One reason is we are wanting to do most of the work ourself. I think when you get done with something if you have done it yourself it means more to you, than if someone just hands your something that is complete.
Thanks for the help, will look it up now.
with this level of airflow, you'll be maxing out the stock MAF and will need a stand alone engine management system.
megasquirt is cool if you have some computer skills and mechanical inclination, otherwise a nice accel DFI-7, big stuff, or a low end motec would be necessary.
#49
Ok, i have been talking with the people that are building the engine, he said that we could see around 750 Crank Hp with out the turbo. We are going with a GT76 turbo with a FMIC and maybe meth. injection. What would be the expected Crank Hp of this set up, any est.?
