450 Wheel hp lq4 build
Old 05-22-2018, 06:45 PM
  #21
10 Second Club
Originally Posted by MrHorsepowerLSx
450 NA is a long shot and the cam needed to get you there will make street manners suffer, easily obtainable with FI tho. FWIW I was in the neighborhood of 410 RWHP NA with an LQ9, and was running low 12’s.
The truck now has over 600rwhp and I still drive it almost every day
Only point I was saying is that anything over 400 to the tire is going to feel like a monster on the street
Off topic, but would you be willing to list your mods to make 410 rwhp? I have an LQ9 rebuilt on the stand, doing my research now for a future game plan. Would like to stay with cathedral port heads.
Old 05-22-2018, 08:32 PM
  #22
11 Second Club
MrHorsepowerLSx's Avatar
Originally Posted by Sierraman02
Who makes good custom ground cams?
BTR, cam motion, advance inductions, Comp, bullet to name a few
Old 05-22-2018, 08:56 PM
  #23
Sierraman02's Avatar
alright thanks for all the Info
Old 05-23-2018, 10:57 AM
  #24
11 Second Club
Sent to you in a PM, I don’t want to clog up the OP thread
Old 05-23-2018, 03:45 PM
  #25
Ken in AZ's Avatar
I built a 427ci LS3 and only made 430rwhp for way more than $2500
Forced induction is the only way to get there on that budget.
Old 05-23-2018, 04:14 PM
  #26
On a budget lol 3100$ is still over and I would need to get an electric fan and injectors but still think I will go that way easiest way to get 450-500hp
Old 05-24-2018, 07:17 PM
  #27
Exclamation
Got the engine apart to where I think i am for the supercharger pistons look good lifters ect. My plan is to get new oil pump and seal new head gaskets and should I have my heads (317s) cleaned up and checked only 110k miles on them, should I mill them some to get compression up a little even if im running a supercharger thanks again guys.
Old 05-24-2018, 07:34 PM
  #28
11 Second Club
You don’t have to get carried away with the 317’s.
If your going to boost it, I wouldn’t mill the heads any, if you have some concerns about the heads not being square, a light surface cleanup can be performed think .003”, almost nothing removed. But a razor blade does good as well if the heads are in good shape. As far as the oil pump goes, if the motor made good oil pressure before disassembly, I wouldn’t replace it. If you wish you can open up the ring gaps a bit, that will Help the motor survive a little longer against the high combustion heat
Old 05-24-2018, 07:38 PM
  #29
Dont really want to take pistons out but It made like 30-35psi i think I just dont want to blow a head gasket on boost.
Old 05-25-2018, 06:46 AM
  #30
11 Second Club
What makes you think you would blow a head gasket?
Slap some LS9 gaskets on it with some head studs and let it rip
Quick Reply: 450 Wheel hp lq4 build
