421 head selection
Old 08-24-2010, 11:44 AM
Registered User
HDGMC's Avatar
Default 421 head selection
Ive got a LQ4 421 with 4.125 crank, its in a 02 2500HD. right now ive got the stock heads on it. Im looking for a new top end combo starting with the heads, and not sure what heads to go with. The goal is low end torque but i would like it to scream at WOT. I would appreciate any input yall have
Old 08-24-2010, 01:12 PM
Praise The Lowered
RibeiroBJJ's Avatar
On the budget end I would go with a set of massaged L92's with a L92 truck intake 90mm t-body..
If you have some coin to spend ..a set of Trickflows or AFR's with a FAST lsxrt 102mm intake with matching throttle body..
To make the most out of the combo , and get to your goals have Pat g. on LS1tech spec you a cam..Good luck!
Old 08-24-2010, 01:33 PM
Registered User
HDGMC's Avatar
What set of Trickflows or AFR's would you suggest?
Old 08-24-2010, 01:35 PM
lethalperformance's Avatar
225s or 235s im guessin
Old 08-24-2010, 03:25 PM
Praise The Lowered
RibeiroBJJ's Avatar
I was actually looking at Trickflows 235's or AFR's new 245's...Either one is a great set of heads
Old 08-24-2010, 04:36 PM
Registered User
HDGMC's Avatar
Sweet deal thanks for the input
lsxmalibu
09-09-2015 11:08 PM
03regcab sierra
09-09-2015 02:02 PM
axekick
09-07-2015 07:01 PM
stock48
11
08-18-2015 05:55 AM
sauldgold
07-23-2015 02:15 PM
Quick Reply: 421 head selection
