421 head selection
Ive got a LQ4 421 with 4.125 crank, its in a 02 2500HD. right now ive got the stock heads on it. Im looking for a new top end combo starting with the heads, and not sure what heads to go with. The goal is low end torque but i would like it to scream at WOT. I would appreciate any input yall have
On the budget end I would go with a set of massaged L92's with a L92 truck intake 90mm t-body..
If you have some coin to spend ..a set of Trickflows or AFR's with a FAST lsxrt 102mm intake with matching throttle body.. To make the most out of the combo , and get to your goals have Pat g. on LS1tech spec you a cam..Good luck! |
What set of Trickflows or AFR's would you suggest?
225s or 235s im guessin
Originally Posted by HDGMC
(Post 4525827)
Originally Posted by lethalperformance
(Post 4525829)
Sweet deal thanks for the input
