408 oil pump/ timing chain
Old Jul 28, 2010 | 10:27 AM
skinumback's Avatar
Default 408 oil pump/ timing chain
what is the best oil pump/timing chain combo to use?
Old Jul 28, 2010 | 10:34 AM
Atomic's Avatar
I have a gauge for that
im going to use an ls6 pump and double timing chain set
Old Jul 28, 2010 | 10:36 AM
skinumback's Avatar
does that require any grinding on the pump or cover? thats what im trying to ovoid!!
Old Jul 28, 2010 | 10:42 AM
Atomic's Avatar
The timing set includes small spacers for the pump, but I havent checked clearence on the timing cover yet. It seems some do and some dont, and if there is any, it is very minor.
Old Jul 28, 2010 | 10:50 AM
supercharged680's Avatar
cloyes timing chain are the best.. and high volume melling oil pump #10296
Old Aug 15, 2010 | 11:22 PM
zippy's Avatar
I agree. With my 408 I'm going to run a stock chain and a D.O.D. pump. I'd recomend picking your timing chain based on how much spring pressure you plan to run. The more spring pressure you run, the more load it takes to turn the camshaft.
Old Aug 16, 2010 | 07:25 AM
tarinitup's Avatar
9 Second Truck Club
Been using 05+ timing chain and ported melling oil pump for 3 years now. I'm sure there is better but that has worked for me.
5.3Okasai
Mar 9, 2022 01:07 PM
The_W
Oct 28, 2015 09:00 PM
chevyl33
Aug 24, 2015 08:21 AM
Ammadien
Jul 22, 2015 08:50 PM
abey15
Jul 13, 2015 02:20 PM
