408 cam?
Old Nov 9, 2015 | 11:54 AM
Moneypitt's Avatar
Default 408 cam?
I am doing a 408 for a silverado ecsb bracket racer, race weight of about 4000lbs. This truck will see quite a bit of road time as I am 1.5 hours from the track. I am shooting for 600-650 fwhp on 93 pump gas with a SC of about 11.2:1 the specs are:
LQ4 iron block bored 4.030
K1 4" stoker crank
K1 6.125 rods with ARP 2000 bolts
Wiseco -3cc pistons
Chev performance CNC LS3 heads 68cc chambers
Intake will be a Holley EFI LS Mid-Rise Intake or similar
This is the cam that has been specified
.312/.277 lobe lift
291/302 adv
238/245 .050
106/118 centers
112 lobe separation
Still need to figure out lifters, rockers and springs.
Will this cam get the job done? Any opinions?
Old Nov 9, 2015 | 12:07 PM
Vortec350ss's Avatar
Pretty decent but not nearly enough lift...
Old Nov 9, 2015 | 12:18 PM
Moneypitt's Avatar
So you don't think it will hit my HP goals, I went with a 408 instead of a 370 so I would not have to push the motor to the max to get to the HP I am looking for.
Old Nov 9, 2015 | 12:26 PM
its only .530 intake lift and .470 exhaust lift. With the LS3 heads I would want .600 on the intake side and close to that on the exhaust side.LS3 heads love the lift because of their huge valve.
Old Nov 10, 2015 | 09:52 PM
lsxperformance's Avatar
I have a 237/250 111+5 that is in that ballpark on a 404 trail blazer your gonna want a nice converter I ran a high rise 102 intake it likes to spin 7200 on the shifts, I'd run Oe rockers w/ quality reunion kit, a quality dual spring kit around 170lbs@ seat, caddy gmpp lifters with new lifter guides.
That head has a decent port, the valve job is where it falls short. There is power to be had for little investment there. The cam I ran is in a street/strip truck was originally intended for nitrous, if I was gonna change anything I'd go bigger and tighten the split to 8* if your doing a na setup. Personally I'd do like a 243/251 somewhere in that area. Will still have decent drivability with a set of 456 gears and a 4500 stall
Old Nov 10, 2015 | 10:07 PM
GREENSIERRA's Avatar
I have a 240-246 630-604 113+3 that I just pulled out of my 408. cam worked amazing
ls1stang
Oct 15, 2015 11:41 AM
redbird555
Sep 30, 2015 09:28 AM
Slammed silverado
Sep 28, 2015 06:14 PM
Parriott31
Sep 22, 2015 08:44 PM
5.3lSilverado
Sep 20, 2015 06:48 PM
