408 20-24psi ring gap question
Old 08-02-2013, 07:04 PM
BGERALD's Avatar
Default 408 20-24psi ring gap question
Hey guys me and my buddies have a 408 ready to be assembled. Going to put the rotating assembly in tomorrow. Just wondering what y'all recommend gapping the rings to. Well be around 18 psi to start for tuning and end up at 24 pounds. CR Will be 9.79:1. Wiseco -15cc pistons, 64cc p&p 243s, 4.060 .040 HG..I believe my calculations are right. We're thinking .24 top and .26 bottom. Will not see spray. Twin 65mm turbos. Thanks for any insight and knowledge..this is our first time building an engine but I think we're on the right track
Old 08-03-2013, 07:26 AM
Gadgetized's Avatar
Thats what I have mine at in my 370. What rings are you using?
Old 08-05-2013, 04:46 PM
BGERALD's Avatar
They're rings that came with the wiseco pistons
Old 08-06-2013, 03:17 PM
BGERALD's Avatar
Bump for more answers..plan on assembling when I'm more comfortable with our ring gap choice. Anyone else?
Old 08-06-2013, 03:56 PM
oakley6575's Avatar
I'd probably open them up a bit more than that but not much.
Old 08-13-2013, 11:06 AM
BGERALD's Avatar
What do u suggest
Old 08-27-2013, 11:04 PM
1994Vmax's Avatar
In the same boat here. My rings work out to basically 25 thou for the top and 15 thou for the second ring based on the ring manufacturers recommendation for a boosted engine. This is from the formula provided and my bore size. So... with a turboed 370 that will realistically see up to 20 lbs boost should I open the second ring up? I am running diamond forged pistons in it.
Old 08-28-2013, 12:02 AM
06blackedout's Avatar
hi I was just wondering about your post description running the -15cc pistons.im fixing to purchase some myself and read a 10.2 cr ratio on a 65cc head.i know the 243's are 64 but not much different I was planning on running 243's p@p as well on my lq4 6.0 .30 bored 408 but with -20cc wiseco's. just wondering what difference there is and what did you do to come up with 9.79:1 on -15cc pistons. Im assuming its the 4.060 .040hg but I don't know what that refers to 100%. thanks
Old 08-29-2013, 08:56 PM
Nocturnal Performance's Avatar
A machine shop told me .004 gap for every inch of bore on N/A and .006 for every bore inch turbo.
chevy6.0fan
08-20-2015 07:10 PM
Cammed4ever
08-20-2015 10:47 AM
JordanH
08-08-2015 07:59 PM
USMCvet0311
08-01-2015 07:45 AM
Gadgetized
07-18-2015 02:15 PM
Quick Reply: 408 20-24psi ring gap question
