4.8L heads...
Old Jul 29, 2006 | 01:15 PM
98hardtopZ's Avatar
Default 4.8L heads...
just a quick question for a friend...he has a 4.8L silverado reg. cab. is the only difference between the 5.3 and 4.8 the heads? if so, could he just buy a set of 5.3L heads and bolt em on?
Old Jul 29, 2006 | 01:35 PM
Last Call's Avatar
TOTM: January 2007
I think the heads are the same. The added dispacement comes from the crank which creates a longer stroke.
Old Jul 29, 2006 | 01:36 PM
willyfastz's Avatar
Restricted User
The 4.8 has a 3.779 bore and a 3.268 stroke which = 293ci
The 5.3 has a 3.779 bore and a 3.622 stroke which = 325ci
So switching heads from a 5.3 will not give him a 5.3 engine. A good set of heads and cam will give him some good power though.
Old Jul 29, 2006 | 01:40 PM
Vortec350ss's Avatar
Do they have the same heads? Is the compression in the 4.8 lower then in the 5.3? With less displacement wouldnt the same size combustion chamber in the heads make the compression lower?
-Rob Nap
Old Jul 29, 2006 | 01:50 PM
98hardtopZ's Avatar
are there any threads on head/cam swaps on 4.8L's
Old Jul 29, 2006 | 02:13 PM
willyfastz's Avatar
Restricted User
It would be the same as all the other LSX engines.
Compresion on the 4.8 is 9.47
Compresion on the 5.3 is 9.49
Old Jul 30, 2006 | 09:25 AM
tdrumm's Avatar
-Rob Nap
Heads are exactly the same. 4.8s have flat top pistons, and the 5.3 has dished pistons.
Old Jul 30, 2006 | 12:20 PM
Oh ok, thanks for the info!
-Rob Nap
Old Jul 31, 2006 | 09:07 PM
moes04silverado's Avatar
FACT!!!
Tydriver
45
Oct 23, 2015 09:19 PM
lycominghunter
26
Sep 25, 2015 07:50 AM
Big_pimie
Sep 22, 2015 09:07 PM
