4.8L heads...
just a quick question for a friend...he has a 4.8L silverado reg. cab. is the only difference between the 5.3 and 4.8 the heads? if so, could he just buy a set of 5.3L heads and bolt em on?
The 4.8 has a 3.779 bore and a 3.268 stroke which = 293ci
The 5.3 has a 3.779 bore and a 3.622 stroke which = 325ci
So switching heads from a 5.3 will not give him a 5.3 engine. A good set of heads and cam will give him some good power though.
Do they have the same heads? Is the compression in the 4.8 lower then in the 5.3? With less displacement wouldnt the same size combustion chamber in the heads make the compression lower?
-Rob Nap
-Rob Nap
-Rob Nap
-Rob Nap
Tydriver
45
Oct 23, 2015 09:19 PM
lycominghunter
26
Sep 25, 2015 07:50 AM
