4.8L build to 366 c.i.
Old Mar 21, 2008 | 01:45 PM
  #21
GoatChs's Avatar
I may be wrong, but I believe that the oem bore for the 5.7L LS1 is 3.898"?
EDIT: Found a source...
ENGINE: Liters: Cubic I: Bore: Stroke: Rod Length: Comp:
LR4 4.8 293 3.780 3.268 6.276 9.5
LM7 5.3 325 3.780 3.622 6.098 9.5
LS1 5.7 346 3.898 3.622 6.098 10.1
LS6 5.7 346 3.898 3.622 6.098 10.5
LQ4 6.0 364 4.00 3.622 6.098 9.4
Old Mar 21, 2008 | 01:54 PM
  #22
r3dh4tch's Avatar
I hear mixed results on this... But thanks for correcting me if I'm wrong. Either way, if I were to bore the engine out more then .040", the next biggest piston I can get is for a LS1, without having one custom made. Reguardless if it's a 3.898" or 3.903" bore, it's a hell of a lot more then .040" over.
Old Mar 21, 2008 | 02:15 PM
  #23
kbracing96's Avatar
It is my understanding that GM designed and cast the 5.3 block to have the capability to be a 5.7 as well. They just never put it into production. That's why there have been no problems with taking them that far over.
Old Mar 21, 2008 | 08:22 PM
  #24
fastgmc53's Avatar
14 Second Truck Club
So what is the stock stroke of the 5.3's crank and what is the most they can be bored to? can 4.00 inch bore be achieved?
Old Mar 21, 2008 | 11:01 PM
  #25
kbracing96's Avatar
Stroke is 3.622 stock, and no you can't go to a 4" bore. 3.903 is pretty much the limit. You need a 6L block for a 4" bore
Old Mar 22, 2008 | 11:28 PM
  #26
PappyDan's Avatar
Tribe Shaman
Originally Posted by r3dh4tch
Mahle makes forged pistons in .010, .020, .030, .040" over stock 4.8/5.3L bore (3.780"). I guess I can take my block to a machine shop and see if they can sonic check it and see what kind of material would be left over in all the cylinders if I do decide to go with a 3.903" bore.
well hot damn, provide me with a link, summit or jegs don't carry them.
Old Mar 23, 2008 | 08:30 AM
  #27
fastgmc53's Avatar
summitracing.com or jegs.com
Old Mar 23, 2008 | 10:29 AM
  #28
old motorhead's Avatar
Sounds like you're going after some pretty serious HP. I wouldn't even consider doing a project like this starting with a 4.8/5.3L block. You'll likely replace everything in the block and just use the block....right? How much, % wise, would it cost extra to start with a better block? I bet a small % compared to the whole project. Sounds to me like you need to start with a 6.0L block and use that 4.8 for a boat anchor. I've been told they'll hold a sizable boat in some pretty deep and stormy waters........
Old Mar 25, 2008 | 05:19 PM
  #29
r3dh4tch's Avatar
Here's a link to the Mahle Catalog. It's in PDF form.
http://www.mahle.com/obj.nsf/79F2ED4E66CA2DE1C1256BC80056FA3C/$FILE/Mahleinc_cat03_21_02.pdf
Old Mar 25, 2008 | 05:30 PM
  #30
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Last time I looked, 6.0L blocks were around $600.
