4.8 worth of a cam?
Old Aug 24, 2015 | 07:03 PM
luis_bullz's Avatar
Default 4.8 worth of a cam?
Im debating into camming my 2010 gmc sierra L20 4.8 or not. I have lt headers, 3000 stall, 4.30 gears, k&n, bb tune. Runs pretty good can keep up with 6.0s and beat hemi's but still want more. Just wondering if its worth the money to put a cam into a 4.8 or just spend that to get a 6.0. What do you guys think?
Old Aug 24, 2015 | 07:35 PM
FFDP's Avatar
I'd cam the 4.8.
Old Aug 24, 2015 | 07:55 PM
black00chev's Avatar
Slowest turbo build ever!
Yeah I would definitely do it... Rev that sum bitch up!
Old Aug 24, 2015 | 08:01 PM
luis_bullz's Avatar
should i go with the comp cams 214/228 or the eps 214/220? i know you can't put a big cam since the displacement the 4.8 has
Old Aug 25, 2015 | 03:19 PM
06 4.8's Avatar
I'm gonna have to disagree.. You will have roughly 1k in parts and speaking from personal experience (had a 224 cam in my 4.8) then swapping to a lq4 in my first Silverado, the stock lq4 would walk all over the cammed 4.8
My NA lq9 walks boosted 5.3s also. No replacement for displacement
Old Aug 25, 2015 | 03:57 PM
gamble686's Avatar
Is it worth it? Yes. You will be at least $1000-1500 into it.
Cam kit $650 pushrods, cam, valve springs
Cam install kit $180 gaskets, fluids, etc
I would recommend LS2 timing chain, trunion upgrade, new lifters(if you have more than 100k miles), and a 220/224 cam. Also mill your heads while they are off.
Old Aug 27, 2015 | 04:03 PM
luis_bullz's Avatar
Would the lq9 slide right in my 2010 sierra? or do i have to get a newer 6.0?
Old Aug 27, 2015 | 04:44 PM
ezdaar's Avatar
slips right in like a worn out V... nm, you get it.
Old Aug 27, 2015 | 05:00 PM
RS/SS 4.8's Avatar
10 Second Truck Club
The lq4/9 will slip right in but you will have to modify some wiring. LY6 is a direct drop in but has vvt. Pick your poison i guess.
Old Aug 27, 2015 | 05:15 PM
ezdaar's Avatar
short block, slips right in.
No wire changes.
