4.8 cam swap
Old Jun 27, 2008 | 10:32 PM
InchUp's Avatar
Originally Posted by LS1nut377
well i have a 2002 silverado 4.8 and a t/a and was wanting to put a cam and a few extra goodies on as well but my question is what are the pushrod lengths? and i was wanting to run a tsp 233/239 cam i think its a 603/599 lift or close to, and is that over kill for my 4.8
How about the CompCams XR265 for the 4.8L? I know that thing makes some decent high end horsepower so utilizing the upper 2/3rds of the rev range from 2000-6000 would make for a fun ride. It's a 212/218 .522/.529 on a 114 LSA. Power would really start to come on around 1400 rpm's and pull hard to beyond red line if you let it. In a 4.8L it really is a 1400-7000 rpm camshaft.
By the way that cam you selected, LS1nut377, is a 2800-8640 camshaft.
Originally Posted by GMCtrk
From my little research on cams, I don't understand why people want these cams so big for a daily driver truck. I plan on doing a 210/218 in a 6 liter, but then again I rarely go over 3000 rpm.
You are a rare breed sir. My personal suggestion, stick true to your opinions and even though most on here will bash you for holding firm on a small camshaft just hunker down and take the abuse. There's perhaps 3 of us now who know that camshafts aren't wiggle sticks to be turned at such a high RPM where a Genie comes out to grant unlimited horsepower. That 210/218 cam you've hinted at will most likely make a torque monster out of your 6.0L, so good choice. Just depends on how aggressive the lobes are and the separation angle.
Old Jun 27, 2008 | 11:26 PM
GMCtrk's Avatar
Thanks for the kind words. The cam is the Vinci 062
210/218 .551/.551 112 LSA 52* overlap
I just want a ton of torque and throttle response down low because that's where I drive. And I think that cam will still have a better top end than stock if I do decide to go WOT. I plan on using a trailblazer stall and adding 4.10 gears (from 3.42)
Old Jun 27, 2008 | 11:40 PM
InchUp's Avatar
Perfect cam ya got there. Good find, it'll definitely get the job done.
Old Jun 27, 2008 | 11:44 PM
dirt track racer 81's Avatar
id go with the comp 212 218 in a 4.8..even then it still needs a stall converter to work nicely with it
Old Jun 27, 2008 | 11:47 PM
LS1nut377's Avatar
12 Second Club
well thanks for all the imput ill take it all to the drawing board real soon, but i gota tell ya i love those high rpm's i shift at 7700 in my t/a pulls all the way to it!
Old Jun 27, 2008 | 11:50 PM
the truck intakes suck at high rpms..usually top out around 6300-6500 rpm..besides the heads will not flow what that cam can put out..buy a fast intake and some heads and shift it at 8k
Old Jun 27, 2008 | 11:57 PM
LS1nut377's Avatar
12 Second Club
ah ha so i shall!!!
Old Jun 28, 2008 | 12:11 AM
so do it already..add some juice to it while your at it
Old Jun 28, 2008 | 06:30 AM
03silverado4.8's Avatar
Default cam
I put a 537 in my 4.8 and thats about all you want! took almost 8 hours of dyno tuning and hptune to get straight. I LOVE IT
Old Jun 28, 2008 | 11:29 AM
philntx's Avatar
You need to update the information in your signature....
Where can you fill up a T/A with premium for $45.00?????
