370ci build help
Old Apr 4, 2016 | 07:58 AM
Rocked_Ram's Avatar
Registered User
Originally Posted by Atomic
A good single 80mm will do that just fine on a 6.0 engine. Twin 76s is a 1500hp type of setup.
Any specific specs I should be looking for to hit my target goals? And will an 80# injector get me there?
Old Apr 4, 2016 | 09:20 AM
Atomic's Avatar
I have a gauge for that
At least 85-90lb/min worth of airflow on the compressor in the >70% efficiency range at whatever boost you want to run.
80s will be fine for 700hp, but you are going to need a little more for 900, assuming you mean power at the wheel. 96s@4bar will safely get you there.
Old Apr 4, 2016 | 11:42 AM
Rocked_Ram's Avatar
Registered User
Ok, I'll have to make some phone calls on the turbo. And I figured I would need bigger than 80# as the most I've seen is 834hp.
Old Apr 5, 2016 | 06:36 PM
Rocked_Ram's Avatar
Registered User
What are ya'lls thoughts on an 88/83/.96 T4? I know it's not going to make the top end power of a bigger turbine charger but will this still put me in my power range?
TrickTurbo
Apr 11, 2016 09:54 PM
TAPyvehc93
Mar 10, 2016 08:35 PM
Slow91z
20
Feb 15, 2016 03:51 PM
Robert Cantu
Dodge Parts Classifieds
Jan 27, 2016 01:40 PM
Mark Johnson
Jan 20, 2016 10:03 PM
