370 VS 390 build
Old Dec 23, 2014 | 11:55 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
Default 370 VS 390 build
well I'm looking at building a motor this winter I'm leaning towards a 370 stock crank callies H-beam rods Wiseco -11 dish 2618 pistons
but I've been looking at building a 390 I'm just having a hard time finding the right pistons and rods i know i need a 3.90 stroke crank what length rods would i need 6.125 or 6.200
i know the 370 will be cheap and reliable
but id love to build a 390 which will be more expensive
ill be running a procharger D1SC but i plan on doing a F1 down the road
Old Dec 24, 2014 | 12:15 AM
oakley6575's Avatar
Have you thought of going with a 3.800" stroke and a bigger piston to reach 390ci? Not much of a difference but should be a stronger set up in theory. You'll need 6.125" rods
Old Dec 24, 2014 | 12:28 AM
I've looked at the AES 390 and they use a Callies 3.825 stroke crank 6.125 rods and custom pistons
Old Dec 24, 2014 | 01:13 AM
Vortec350ss's Avatar
When starting with an iron block you are pretty limited as to how you can reach 390ci
Kurt's on the right track with a 3.825 stroke and a 4.030 bore.
Old Dec 24, 2014 | 07:23 AM
I'm gonna call AES and see if they'll sell me a set of there custom Pistons then all I need is the crank and rods
Old Dec 24, 2014 | 01:19 PM
oakley6575's Avatar
Yea 3.825" is what I was thinking of. Nobody makes pistons for that stroke besides AES?
Old Dec 24, 2014 | 05:04 PM
Aes uses custom diamond pistons. He just orders large batches of them. No ine makes an off the shelf though. Not as far as I've seen.
Old Dec 25, 2014 | 01:59 AM
or a 3.825 crank with 6.200 rods and off the shelf 408 pistons comes out to 390 CI not sure if it would work or not
Old Dec 26, 2014 | 11:40 AM
called AES today $3,300 for the whole rotating assembly not balanced
$1,100 for pistons with file fit rings ouch!!!
i can get rods and pistons to build a 370 for $1,200
OHsixLS3
Sep 25, 2015 11:20 AM
2500ZL1
Sep 12, 2015 03:50 PM
MA$TER_E
Sep 9, 2015 03:14 PM
PDPERFORMANCE
Sep 8, 2015 11:01 AM
USMCvet0311
Sep 4, 2015 09:43 PM
