6.0 vs 6.2..... 12cu in worth it?
Old Dec 10, 2014 | 04:29 PM
Pro52R's Avatar
Default 6.0 vs 6.2..... 12cu in worth it?
Ok, I I recently acquired a L76 short block. Stupid cheap. Needs a rod bearing. Originally, guy though it was a L92. Oh well, still stole it.
So, my question is. How much would I leave on the table, potential wise? This will most likely be going in a 5100lb Yukon. Cam and stall are a must. I'd like to see 12s.
Cathedral or Rectangle heads? I see boost in the future as well.
Should I get this short block refreshed and sell for a 6.2 or am I not missing much.
Old Dec 10, 2014 | 11:26 PM
Vortec350ss's Avatar
You arent missing all that much... especially if boost is in your future.
12's at 5100 lbs will take a fairly aggressive build NA, but it will be a cake walk with boost. You will need north of 450 to the wheels to accomplish 12's.
I'd probably go square port. I have a new respect for them after doing some research and talking to experts that have built careers around cyl heads... I'd also put a maggie on it... but I'm biased.
For what its worth my race weight is 250# more than that and I just went 11.43 with a 6.0 and a maggie.
Old Dec 11, 2014 | 03:12 AM
Pro52R's Avatar
I figured I'd need 450+. I also was thinking 821 heads. Probably do a port job on the exhaust. And if I have to. Maybe a 150 juice shot, until I can go turbo. Not like I'm going to be thrashing it on the daily.
Old Dec 11, 2014 | 01:48 PM
69Camaro427's Avatar
Does the 4" 6.0 bore have to be bored for the larger l92 valves to work?
Old Dec 11, 2014 | 02:28 PM
No, they fit.
Old Dec 12, 2014 | 12:19 PM
53bowtie's Avatar
They "fit" but it is not optimal to run the larger valves on the small of a boar. I think Skeet got it to work pretty well but he had to do a lot of work on the chambers of the head I believe to take care of shrouding from the valves being so close to the cylinder walls. I will see if I can find the thread..........
Old Dec 12, 2014 | 12:25 PM
53bowtie's Avatar
Here is the thread......
https://www.performancetrucks.net/fo...3-swap-522931/
See posts 5 & 6. Can be done and may have good results but without extensive head work like what Skeet had done cathedral port head may be better for a 4" bore application.....
Old Dec 26, 2014 | 05:59 PM
cooter1989's Avatar
Should be a whicked grocery getter lol
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
Cammed4ever
Sep 30, 2015 03:38 PM
sTNT971
Sep 26, 2015 04:22 PM
