370 Build..
Old Feb 11, 2008 | 11:41 PM
jakebdb56's Avatar
Depending on the valve timing, you might have some PTV clearance issues. What cam are you putting in the 370?
Old Feb 12, 2008 | 12:22 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
P to V has nothing to do with your quench area. Dirt generally the aftermarket 6.125 rod with the correct pistons will put you at +.008 +/- .001, I would order the run-of-the-mill .04 cometic and go on down the road since its a common size and thickness.
Old Feb 12, 2008 | 06:36 AM
dirt track racer 81's Avatar
thats the gasket i had in mind last night
cam is the same cam i got now 230 226 597 563
Old Feb 12, 2008 | 07:58 AM
onebadrubi's Avatar
you need to find you a set of 317's or 243's and scrap those 241's. Those are the crappiest gen 3 heads out thier.
Old Feb 12, 2008 | 08:06 AM
truckmann's Avatar
Originally Posted by dirt track racer 81
i already had arp heads bolts im just going to reuse them..can you explain quench more or have a link to it?
Correct me if I'm wrong, but doesn't TTY bolts mean they are suppose to be one time use bolts?
I thought after they are stretched to the proper torque specs that it is not good to try and re-use them. Just would suck to spend all of this money and run into problems cause of some head bolts.
Old Feb 12, 2008 | 08:13 AM
1slow01Z71's Avatar
ARP bolts arent TTY so you can reuse them. Stock bolts are TTY.
Old Feb 12, 2008 | 01:05 PM
truckmann's Avatar
Cool I didn't realize that. Thanks.
Old Feb 12, 2008 | 02:34 PM
ZZebes's Avatar
Definitley get some better heads
Old Feb 12, 2008 | 10:20 PM
the heads have been ported..but i dont know what they would flow..how much milling does it take to get 317 heads to 66-67cc's and what length push rod would i need?
Old Feb 15, 2008 | 07:26 PM
heres 2 pics of the mahle pistons and h beam rods i got
