370 Build..
P to V has nothing to do with your quench area. Dirt generally the aftermarket 6.125 rod with the correct pistons will put you at +.008 +/- .001, I would order the run-of-the-mill .04 cometic and go on down the road since its a common size and thickness.
I thought after they are stretched to the proper torque specs that it is not good to try and re-use them. Just would suck to spend all of this money and run into problems cause of some head bolts.
Correct me if I'm wrong, but doesn't TTY bolts mean they are suppose to be one time use bolts?
