346 vs 370
Old Oct 12, 2009 | 07:05 PM
006rcsb's Avatar
go 6.0 it has a 4" bore and can use heads with bigger valves, like l92 heads and those heads flow really well, it would have more potential. the 5.3's cylinder walls get kinda thin when boring out that much, and the block has to have been casted really well or it cant be bored out all the way because there would be a thin side to the cylinder. there is alot more money involved with stretching out a 5.3.
Old Oct 12, 2009 | 07:19 PM
Go5.3tt06's Avatar
How about 317 heads cux im going to turboed
Old Oct 12, 2009 | 07:20 PM
GMCtrk's Avatar
no you arent
Old Oct 12, 2009 | 07:23 PM
Go5.3tt06's Avatar
When your trying or wanting to make big hp, mileage should not even be a concern.. Hp burns fuel.. The 370 is a bigger engine and will burn more fuel...Unless you have a fuel mileage tune done for it. In that case it would be pointless to have even built a engine for power..
Im trying to understand. You mean if I tune for 370 will better mpg not killer. I plan to run with turbo. Suppose to make some better mpg on 370 right? I know if you floor to much it will eat up gas. Just like drive as regular it will be better right?
Old Oct 12, 2009 | 07:26 PM
Mangled03gmc's Avatar
Baltimore Whore
If your going to do it, I would do the 370.. Your going to spend about the same to do both. So go with bigger cubes for close to the same price...
Old Oct 12, 2009 | 07:29 PM
charcold-bowtie's Avatar
Originally Posted by GMCtrk
no you arent
you arent either
Old Oct 12, 2009 | 07:33 PM
GMCtrk's Avatar
Old Oct 12, 2009 | 07:58 PM
Go5.3tt06's Avatar
no you arent
So cant use 317. Need other L92 for good setup turbo?
Old Oct 12, 2009 | 08:00 PM
Go5.3tt06's Avatar
I might stick with 370 from texas-speed if they sell cheaper. But Im kinda afraid if it would be killer gas. Because this is my daily drive. Thats why I just curious about MPG. Also want to compare with stock 5.3 and 6.0 mpg
Check-
http://speed-eng.com/store/lq9-engine-block-p-8772.html
http://www.texas-speed.com/shop/item...d=683&catid=83
Any other link you know of that will be cheap or whatever it is. Just want to see that engine/ heads etc already built up just ready to go put in truck and play.
Old Oct 12, 2009 | 08:02 PM
GMCtrk's Avatar
the 6.0 will get significantly worse mileage.
