32 Valve LSX heads???
Old Jul 24, 2009 | 11:35 AM
  #21
philntx's Avatar
According to the website:
-Intake port flow is 405CFM @ .600” lift
-The intake ports are standard LS-7
-There is a huge gain in Horsepower over a 2 valve head. To the tune of 100HP more using the same induction, exhaust, cam etc.
_The heads come with everything necessary to convert to 32v. Pair heads fully assembled, pair valve covers, rocker assembly and shafts. $7499.00
A lot of money, but if you were looking for a unique powerplant.............
http://araoengineering.com/LSX.htm
Old Jul 24, 2009 | 06:10 PM
  #22
jlwz71's Avatar
Originally Posted by skyhighsami
Uh....usually the main benefit to billet is it's weight or lack there of.
I will rephrase (you are correct) . Even though its aluminum billet there is a lot of unneeded weight there. There is more spring pressure at the pushrod tip of the rocker so it has to be large and bulky to handle the stress. I would be very hesitant to run an engine up to the 6500 rpms that a lot of people here do for any length of time (day to day driving) with a lead foot.
The idea is great, its just my opinion there is a lot of complication in that design while the two valve heads for these engines flow really well without the "exotic" engineering.
This engine was designed for two valves. When I was younger (1980 or so) I can remember aftermarket heads for the small block that had 4 valves per cylinder. Not much amounted to it. I am all for innovation but I would like to see them on a test mule.
JMHO
Old Jul 24, 2009 | 06:41 PM
  #23
616 of 933's Avatar
i would think you would get more power out of a set of L92's
Old Jul 24, 2009 | 08:10 PM
  #24
Fastcount03's Avatar
Especially for the money! Take and dump a grand into a set of L92's and I'm sure you would have a way better set of heads with cash left over!
Old Jul 24, 2009 | 08:13 PM
  #25
Very true, but look at these heads... They are monsters compared to a stock casting, so really the valvetrain itself may be lighter but you gaining a ton of weight with these heads.
Old Jul 24, 2009 | 09:14 PM
  #26
MikeGyver's Avatar
Even though they claim 400 cfm intake flow, that is not the point of 4 valves per cylinder. The main benefits are 1. low lift flow, which will be way better than two valves, and 2. combustion chamber shape, which is almost ideal with 4 valves. I don't think 100 HP gain is unreasonable.
Old Jul 26, 2009 | 11:51 AM
  #27
TexasPainter's Avatar
Banned
for all that effort, why didnt they just make them OHC? :scratch:
Old Jul 26, 2009 | 03:19 PM
  #28
PathfinderJr's Avatar
blasphemy!!
haha..
Old Jul 27, 2009 | 12:27 PM
  #29
Red04Silverado's Avatar
Meh........
The_W
Oct 28, 2015 09:00 PM
subeone
Aug 19, 2015 07:44 AM
omc8
Aug 10, 2015 10:39 PM
BigEd_72455
Aug 8, 2015 04:49 PM
jmarkway
Jul 18, 2015 09:23 PM
