317 heads
Old Nov 11, 2010 | 07:52 AM
ihdude's Avatar
Default 317 heads
I have an LQ4 that I will be putting in a EPS 226/230 cam in the near future. Would it be worth to have the 317 heads reworked with a comp valve job, some milling, smaller head gasket, etc? What kind of gains should I expect? Would it be better to find a set of 243s with no machine work? This is not a long term engine set up so penny pinching is a must. What kind of costs for the machine work?
Old Nov 11, 2010 | 09:07 AM
Atomic's Avatar
I have a gauge for that
Most shops I talked to wouldnt touch heads for less than $1000 just for labor. Wasnt worth it in my opinion, especially since I am FI.
Old Nov 11, 2010 | 11:17 AM
D_reks{5.3}'s Avatar
Hit up a sponsor over on ls1Tech called fasterproms I think. They have 243 heads with under 30k miles that they port, mill, and bowl blend depending on what all you want. A lot of people on tech are using them. Thats where I got my 243s aswell. I got the option 2 package which consists of mild port polish, Bowl blending, And a .010 mill. for $750 shipped, But then I had them add PRC dual valve springs. I ended up paying right at $1k shipped for springs and everything. And they supply the heads.
Old Nov 11, 2010 | 11:43 AM
budhayes3's Avatar
PT's Slowest Truck
WCCH (sponsor, link to the right>>>) has a nice CNC'd stageII 317 head that they offer, I have them, but have yet to bolt them on to my LQ9. They are a bit pricey though. It would be worth it to talk to Richard over there, he is extremely knowledgeable and won't steer you wrong
Old Nov 11, 2010 | 11:45 AM
LS1FREEK's Avatar
13 Second Truck Club
My local machine shop will do head milling up to .100" for $80 for the pair.
Old Nov 11, 2010 | 12:02 PM
If you have the cash, Richard is definately someone to talk too.
Thats the typical price around here too.
Old Nov 11, 2010 | 02:12 PM
02Denali6L's Avatar
Either way you definitely will need LQ9 or higher compression for that cam...
greedygenius
Sep 3, 2015 06:51 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Azim05
Aug 27, 2015 05:33 PM
darnie
Aug 10, 2015 10:25 AM
JordanH
Aug 8, 2015 07:59 PM
