243's or LT's with the Comp 265 Low Lift cam?
Old Oct 14, 2011 | 08:49 PM
Bigschwerm's Avatar
Take .040 off your 706's
Old Oct 14, 2011 | 10:11 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by DMM
Any idea how much to mill off my 706 heads? 0.015" - 0.025"? The guy at the machine shop balked when I asked about milling the heads.
Find a new machine shop then...milling heads on these engines is common practice
Old Oct 15, 2011 | 06:18 PM
DMM's Avatar
DMM
What kind of comp ratio would that give me?
Old Oct 16, 2011 | 11:24 AM
DMM's Avatar
DMM
Got it...
5.3 with .040" milled 706 head = 10.13:1 with a 3.910 bore .054" thick head gasket.
5.3 with .025" milled 706 head = 9.87:1 with a 3.910 bore .054" thick head gasket.
Thinking I might want to go .025" to keep using regular 87 octane fuel.
Old Oct 16, 2011 | 12:50 PM
budhayes3's Avatar
PT's Slowest Truck
Got it...
You can use 87 with 10.13:1 static compression depending on what cam you choose and how much overlap it has. You need to figure out what your dynamic compression ratio will be, and you can also play around with the timing tables to keep the engine from detonating. As much compression that you can run without detonation will be beneficial to your low/midrange that you're looking for. Considering that the SilvySS came with 10.08:1 from the factory, with the factory bumpstick, I'd have to *guess" that 10.13:1 with a larger cam would be good to go as long as you don't get crazy with ignition timing. I do believe that GM recommended at least 91 octane on the SS's, but I'm not 100% sure on that.
Maybe split the difference between .025 and .040 and go for like a .030ish mill or something
chopperloco
Jul 10, 2016 10:45 PM
LARRY01Z28
Aug 1, 2015 10:15 PM
OLD BULL
Aug 1, 2015 05:00 PM
Castro45
24
Jul 31, 2015 07:13 PM
07NBSChevy
20
Jul 8, 2015 07:27 PM
