243 Z06 Heads and Cam On an '03 5.3
#21
You claim to have the oringinal heads from a vette which have a longer valve in them to make up the diff from the cams smaller base circle
if i was you i would run a 7.350 pushrod since your milling .040 off
Stock is almost 7.4 its like 7.39??
#22
Ok, thanks for the tip. Yeah, the heads and cam came off a low mile '04 Z06. The cam is pretty small, but I'm not looking for a big gain there and I like my DD being nice and smooth, plus I plan on throwing a roots blower on here eventually and that cam should go nicely with it.
#26
I'm looking to do the same thing and I plan on turboing mine.
I need zo6 cam, 243 heads milled .040 and a thin gasket? Any thing else that I missing?
Thanks
Thanks
#27
If I'm reading this right by milling the heads you lower the compression? If so then if your goals are to boost the motorthan it would be better to keep the stock 5.3 heads and mill them Down use a thin gasket and then boost?
Thanks
Thanks
#30
