243 heads and Z06 cam swap
#22
I have a new ? As I was disassembling last night, I noticed that each rocker arm is labeled different. Does it really matter where each one goes? I recorded each's location so if need be I can put them back where they go. Also, before I started this i was told that I needed to change lifter no matter what? But when I pulled the stock ones out they appeared to be in "new" condition. My motor only has 87,000 on the clock. Well I am goin back to work, so if anyone knows the answer, please feel free to let me know, and thanks ahead of time.
#23
no not really a need to replace the lifers unless they are ticking. the rocker arms should sit in the stand all in place, but i would make sure they go back in the same spot because of wear characteristics on the top of the valves
#24
Check the lifters yourself. Push the plunger in with the tip of a pushrod on each of them to make sure everything still works. Compare one against all the others to feel how hard/soft you need to push to make the plunger go down, and to spin the roller tip on the end. If all check out, put them in a little bag and reuse them.
Any part of the valve train that you reuse it's a good idea to label where things came from and put them right back. I follow this rule to an extent, but ended up bolting on different lifters than what I took off during my mostly-stock rebuild so take the "rule" as a word of advice to avoid mix ups during the rebuild.
I guess I'll just have to swap it out for a 6 speed!!
