243 heads need advice
Currently have a 03 gmc ext cab5.3 with a 224/230 114 lsa cam longtubes full exhaust 373s and 3200 stall 125 shot . Was thinking about swapping my heads for some 243s worth it ? Thanks in advance
At the moment I do not have them but I need to swap my lifters and might aswell change my heads how much should I get them milled ?
11 Second Club
The 243 heads flow a little better and have bigger intake valves, but unless you mill them, it'll lower the compression ratio compared to the 5.3 heads. So, not much advantage unless you mill the 243 heads (assuming you're N/A). The 243 heads really come alive when ported though.
Are you running any nitrous on it ?
Milling 243 heads .020" will put you about at the same CR as the 5.3 heads. Not sure I'd go more than .030" which would be about 59cc chambers.
