243 heads on 5.3
Old Jul 29, 2014 | 07:58 AM
BUDDY23's Avatar
Originally Posted by Joseph Hartley
Would i be alright with PTV Clearence with the TSP 224/224 .581 .581 on a 112LSA with 243 heads milled .030 with a .040 head gasket? and also any recommendations on what kind of head bolts? Like ARP or just GM Bolts? and also are they going to be the Long or short head bolts going from 706's to 243's.
PTV won't be an issue with that cam, but it will be a dog down low with the stock stall TC.
I'd go with the ARP headbolts personally, but the GM bolts will be just fine. The 2003 block will have the long and short bolts.
Old Jul 29, 2014 | 09:13 AM
TXsilverado's Avatar
I would just drop a LQ4 in but i dont want to do a tranny swap to the 4L80E because i bought the truck with a brand new transmisson in it.
the LQ4 will bolt right up to your new transmission
Old Jul 29, 2014 | 03:28 PM
Badlands's Avatar
Lol i wish but this is going to be a DD so id like to keep it somewhat streetable.. no more then 224 cam with 3600 stall
FWIW I run a 228r cam with a 3200 stall (wish it was a little bigger stall) and 3.73s in my DD 4.8 Silverado. Very very streetable and still get 16+ MPG. With that cam and a full exhaust, stock everything else, I put down 345hp/345tq to the wheels. I don't see how that 224r cam with some good heads on a 5.3 wouldn't make at least what I make.
Old Jul 29, 2014 | 07:04 PM
Joseph Hartley's Avatar
Registered User
ARP Bolts it is then!
Old Jul 29, 2014 | 07:08 PM
Registered User
Yeah i know but the Little Ole 4L60E wouldnt like it much lol.. I might do 6.0 4L80E in the future but not atm wanna see what i can do with what i got lol
Old Jul 29, 2014 | 07:30 PM
power is power whether it comes from a heads/cam 5.3 or a stock lq4. all you're doing is getting your 5.3 up to the potential of a stock 6.0.
Old Jul 29, 2014 | 07:58 PM
Registered User
What Head Gaskets should i be running? I want the Cometic .40 but dont know the rest of the details.. bore size etc..
Old Jul 29, 2014 | 08:35 PM
Registered User
True i just dont want the trouble of a engine tranny swap atm.. What bore size head gaskets do i need to get with the 243 heads?
Old Jul 29, 2014 | 09:17 PM
Hubcap's Avatar
On my 5.3 I put MLS ls1 from TPS work fine.
Old Jul 30, 2014 | 10:17 AM
Bilster's Avatar
Try to keep your bore size on your gaskets close to the true bore size of your motor. Any little crevice you create between the head and block mounting surface can dilute your mixture costing you a little power and causing increased emissions.
chopperloco
Jul 10, 2016 10:45 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
steves86ta
Jul 28, 2015 10:21 AM
06 4.8
Jul 15, 2015 07:17 PM
07NBSChevy
20
Jul 8, 2015 07:27 PM
