224/230 lsa 110
Old Jun 27, 2011 | 08:05 PM
06murder's Avatar
Default 224/230 lsa 110
what do yall think an 224/230 lsa 110 would do in a stock 5.3, i have seen some ppl maken 340-350 but they on lsa 114..would it be any different?
Old Jun 27, 2011 | 08:09 PM
SLOXCAB's Avatar
Should work well. I have a 230/230 for sale for cheap. Regrind it for 50 and have whatever cam you want for under 300
Old Jun 27, 2011 | 08:21 PM
06murder's Avatar
oh kool its and carb 5.3 so figured 110 lsa,right? when i get some money i holla at you.. thanks man for ur opinon
Old Jun 27, 2011 | 08:55 PM
f4tal's Avatar
I've seen the 224/230's make 340-350 and thats on a 111-112 lsa
The cam should put the same power down regardless just move the torque curve up or down a few hundred rpms
Old Jun 27, 2011 | 09:05 PM
06murder's Avatar
oh ok i wasnt sure....still learning on the lsa n icl
Old Jun 27, 2011 | 09:21 PM
brandon6.0's Avatar
why u stuck on using the same duration cam as what JB used? try somethin dfferent. Besides u runnin a carb anyways. U could probably get away with runnin a cam a lil bigger than that if u wanted. Best thing is to have one speced by pat g.
Old Jun 27, 2011 | 09:23 PM
06murder's Avatar
same durration but diffenert lift frm tsp, n tsp is cheap then pat g
Old Jun 27, 2011 | 09:25 PM
budhayes3's Avatar
PT's Slowest Truck
I think that it would work well in your carbed 5.3 project...the tighter LSA will bring the power on sooner and allow for a little more peak horsepower, with "peakier" hp and tq curves than a 114, which will have a broader torque curve. I'm thinking that you'll want about a 3600 converter with that grind BTW.
Old Jun 27, 2011 | 09:28 PM
06murder's Avatar
i was thinking more along like a 4000 stall...be up in the power band lil better on the line.n spraying 150 or 200 idk yet
Old Jun 27, 2011 | 09:35 PM
brandon6.0's Avatar
son u still have alot to learn. Pat g only charges 25 dollars to spec u a cam. No cheaper than texas speed. Thats who speced JB current cam in his 6.0
U are correct tho about wanting to run a tight lobe of around 110. Willl work perfect with the short runners on that vic. jr.
