2017 GMC 1500 Sierra 4x4 club cab
Old May 27, 2021 | 06:48 PM
Dtweedy's Avatar
Registered User
Default 2017 GMC 1500 Sierra 4x4 club cab
I would like to know if I swap my 5.3 for a GM Performance 525hp 6.2 - do I need a new ECM or wire harness? I have the 8 speed trans
Old May 27, 2021 | 07:35 PM
FFDP's Avatar
Which exact engine?
Link?
It's not that you need a new computer but you have to have it tuned. I doubt GM sells a tune that is just plug and play with an existing truck.
Old May 28, 2021 | 02:59 PM
Dtweedy's Avatar
Registered User
PART NO. 19369338
I have a mechanic who will do my tune - already have the TCU unlocked and ready to tune that as well
Old May 28, 2021 | 04:50 PM
1FastBrick's Avatar
Custm2500's Rude Friend
That part number is a fuel injected motor. It will Not be a direct drop in.
I believe your truck has Direct Injection
Look at the LT1 PART NO. 19328728 . If you want to bring it up to the same power level Just put a small cam in it.
Or the LT376/535 PART NO. 19355378 this has the GM Gen 5 LT1 hot cam and CNC ported heads.
The factory Gen 5 LT1 camshaft features 200/207 degrees of duration at .050-inches, .551/.524-inches of lift, and a 116.5-degree lobe separation angle.
The GM hot cam for the Gen 5 LT1 is
228/248 degrees of duration at .050-inches, .577/.577-inches of lift, and a 116.5-degree lobe separation angle.
Old May 28, 2021 | 06:02 PM
tjmath's Avatar
If you're looking for a 6.2, I would be looking for a direct injected LT platform. That would pretty much be a direct swap aside from the tuning.
Old May 28, 2021 | 09:13 PM
Dtweedy's Avatar
Registered User
Thank you, the GM Gen 5 LT1 hot cam and CNC ported heads look like a good play - Thank you
Old May 28, 2021 | 09:14 PM
Dtweedy's Avatar
Registered User
Thank you!
Old May 28, 2021 | 09:16 PM
1FastBrick's Avatar
your welcome! let us know how it goes when you get it done.
cosmo22nov
Jul 21, 2018 11:46 AM
JakeBrakeIH
Dec 11, 2010 07:59 AM
SSJIMMY
Jul 23, 2009 07:49 PM
