2003 Silverado Oil Pan Replacement
Old Dec 26, 2010 | 07:32 PM
eville's Avatar
Default 2003 Silverado Oil Pan Replacement
I just got a call from my dad. He cracked the pan on his Silverado when he was trying to jack up the truck. (damn, he knows better than that!)
Anyways, now it will be up to me to fix it.
It's a 5.3L. I have not been over to look at it yet. Will I be able to replace the pan without pulling the engine?
Thanks in advance for any tips.
Old Dec 26, 2010 | 08:04 PM
iamkeniff's Avatar
i dont think you have the room but id look. you can probably unbolt the intake/exhaust/motor mounts and lift the motor up enough. on the gmt900s they have a bracket that can be unbolted to remove the oil pan.
Old Dec 27, 2010 | 07:39 AM
Coban's Avatar
The crossmember under the engine can be unbolted. If I remember correctly, it allows you to take the oil pan off.
Old Dec 27, 2010 | 08:12 AM
1989k1500's Avatar
If its 4wd you will have to take the front diff out, if its 2wd it shouldnt be big job to swap the pan.
Old Dec 27, 2010 | 09:39 AM
Gadgetized's Avatar
What he said ^^^
Old Dec 28, 2010 | 04:34 PM
BlownChevySS's Avatar
You don't have to take the front diff out, just unbolt it and lower it if its a 4wd/awd. Make sure you replace the oil cooler lines gasket too even if it looks reusable
D1SCSS
Jan 25, 2016 10:14 PM
pjb1972
Sep 17, 2015 02:06 PM
Ketis
Jul 23, 2015 12:37 PM
jmarkway
Jul 18, 2015 09:23 PM
