2000 Silverado 5.3 cam and heads
Old Aug 14, 2016 | 08:48 PM
Miguel_nbs's Avatar
Registered User
Default 2000 Silverado 5.3 cam and heads
Hey guys I have 5.3 in my 2000 ext cab Silverado it has 410 gears truetrac posi CAI long tubes & tuned by cal speed. I am doing a cam swap I'm putting in a 228/232 110 lsa 600 lift @.50 Its a TSP cam with their 660. Springs and 7.400 PR, I'm also doing LS7 lifters , ls2 timing chain , and P&P 243 heads and bigger valves and stock ls6 head gasket with ARP head studs but I want to mill the heads .30 to get stock compression but I'm not sure if I will have pvt issues please help thanks
Old Aug 15, 2016 | 04:55 AM
madmann26's Avatar
Most people are going to tell you it's better to measure to see if you will have pvt issues.
On the heads, how big of a valve are you going to? The 5.3 block is a small bore motor and your options are limited, if any.
For a otherwise stock 5.3, your cam selection is big. I see no mention of a stall but you do mention you have gears.
It's going to be a dog out of the hole with a stock converter.
Old Aug 15, 2016 | 01:27 PM
turboal1's Avatar
Default Cam
Wrong cam for a DD. to much dur.
Old Aug 15, 2016 | 01:33 PM
Miguel_nbs's Avatar
Registered User
I will be using a 3600 or 3800 stall and I believe 2.02/1.60
Old Aug 15, 2016 | 01:42 PM
Miguel_nbs's Avatar
Registered User
I know a couple people who run same duration cam on 5.3 just different lift and lsa and they perform good
Old Aug 15, 2016 | 09:46 PM
LJ93Z28GM's Avatar
I just milled my 243, took off 30 and had them CC'd after which measured in at 61.05
What are you intentions/goals for the truck?
Old Aug 15, 2016 | 09:50 PM
Miguel_nbs's Avatar
Registered User
400 hp to the wheel all motor and spray a 75 or 100 shot sometimes
gotmud2178
May 24, 2016 10:47 AM
JC94Z28
Mar 21, 2016 12:56 PM
turbo39402
Mar 7, 2016 09:35 AM
09CamdSilvy
Mar 2, 2016 09:47 AM
Slammed'99
Dec 3, 2001 01:45 AM
