1st LS 408 engine build
Old Jul 23, 2013 | 09:57 AM
zero2sixT's Avatar
Originally Posted by Batman'sChevy4.8
So by reeacrh you mean speandig every free moment I have at work or home on PT.net typing 408, LQ4, 6.0 build in the search bar right cause I thought thats what I have been doing for the last month. I'm through with the 4.8 I don't want to spend anymore money on that.
400-450 hp to the wheels with a 408 under the hood of a DD is a big enough dog for me and where I race.
Lol ok man, good luck. You seem to have it all figured out.
Old Jul 23, 2013 | 10:28 AM
Batman'sChevy4.8's Avatar
I'm trying to figure out how to mill and get higher compression out of the heads on the stock LQ4.
Old Jul 23, 2013 | 11:50 AM
53bowtie's Avatar
You just answered your own question. to get higher compression you mill the heads. Remember, you can also control compression with the dish of the piston and the thickness of the head gasket as well. You must take into account all three.
Old Jul 23, 2013 | 12:49 PM
zero2sixT's Avatar
Not trying to talk ****, or discourage you at all. But this shows you need to read up on what you're wanting to do.
You don't need more cubic inches to make the power you want, or more. You need to get a solid estimate on what it's going to cost to properly build a stroked engine. Then you need to see what ppl are doing with forced induction on a 4.8 and how much they are spending. Both are expensive, one has a much better bang for the buck.
Old Jul 23, 2013 | 02:01 PM
ok done with the 4.8 want a 6.0 408 lq4 have price looking for head info.just looking for input on heads
Old Jul 23, 2013 | 02:13 PM
I read that about the head gasket in another build thread on here but there wasn't much detail.
I guess the questions I'm asking I should be asking the people at Columbus Engine and crank. What are good numbers to mil the heads to raise compression and is it the deeper the dish of the piston the higher the compression or vice a versa?
Old Jul 23, 2013 | 03:38 PM
zero2sixT's Avatar
Alright cool. Milled 317s are a poor choice.
Old Jul 23, 2013 | 04:55 PM
What if I milled the heads on my 4.8, I've read the 4.8 heads rasie the compression on 6.0s dramaticaly. Would that be better or should I sell both and go for the LS3 or L92 heads?
Old Jul 23, 2013 | 09:57 PM
1/4milelarry's Avatar
I'm a little over $5300 for my bottom end. It not just crank, rods, pistons.. It's all the little stuff that adds up quick. Like bearings, main studs, seals, gaskets, oil pump, timing set up. Rockers heads intake..... The list goes on...
I have a lq9,
Callie's compstar crank- $833
Callie's h-beam 6.125 rods- $597
Wiesco -8cc dome pistons- $860
Arp main stud kit- $241
That's just parts not including bearings or labor or machine work done.
The. A good set of heads will run you at least $2000-$2500, a good intake $500-$1000. I'm gonna have around 8-9000$ into my 408. Before I upgrade fuel, trans work, or have any of it tuned...
Old Jul 23, 2013 | 09:58 PM
Also I'm building mine for boost, and a hp goal of around 900whp
