12571896 Oil Pump
Old Aug 3, 2018 | 05:18 PM
nsm12690's Avatar
Default 12571896 Oil Pump
I bought this oil pump ported new for a CTSV project a while back. Wondering if it works for my 6.0 LQ4 2006 2500hd? 12571896 that's the part number. if not, what is the high volume Melling oil pump needed for this motor?
Old Aug 3, 2018 | 09:44 PM
RB04Av's Avatar
5 Year Member
Should probably work.Not sure what pump is is; a common one that you can buy ported, is the LS6 one. Which works pretty well in most of these motors.
Std Melling pump is M295. HV is 10295. HV/HP is 10296. You can shim the relief spring in either of the 1st 2 (or any other) a little bit to raise their pressure.
Old Aug 3, 2018 | 09:50 PM
nsm12690's Avatar
Awesome! Thank you! I think this is a ported LSA oil pump. So I will be getting the 10296.
SS69LS1
Oct 8, 2013 01:06 PM
CHEVY6000VHO
Jul 20, 2006 11:45 AM
ranwalk
Jan 8, 2005 09:13 PM
