110 lsa cams
Old Jun 30, 2011 | 09:25 PM
2007chevy5.3l's Avatar
Default 110 lsa cams
Anyone use a cam on a 110 lsa? How do you like it? Hows the powerband? Curious to find more info cause all I can really dig up is info on 112-114 lsa cams...
Old Jun 30, 2011 | 09:39 PM
BlackGMC's Avatar
Resident Retard
my old cam was on a 108
Old Jun 30, 2011 | 09:50 PM
MikeGyver's Avatar
What an informative and helpful reply, Corey.
Old Jun 30, 2011 | 09:53 PM
MPFD's Avatar
11 Second Truck Club
Mine is on a 110 straight up. The power comes in really quickly but short LSA cams of larger size are harder to get the idle tuned...
Old Jun 30, 2011 | 09:54 PM
06murder's Avatar
im plan to run an 110 on my carb 5.3...:p
Old Jun 30, 2011 | 09:58 PM
MPFD's Avatar
Carbed motors love short lsa. My buddies carbed L92 is on 106...
Old Jun 30, 2011 | 10:00 PM
06murder's Avatar
im trying to c if i can break some record...ook may not, have tring
Old Jun 30, 2011 | 10:07 PM
Jake99's Avatar
110 is good on extreme ramp cams, lets say you have a 5.3 with a 224r on 112, go with a kr lobe hi lift 224 with a 110, this will give you every bit of the top end just brings the power band in quicker, this will build more compression at the low rpm witch means more torque.
Old Jun 30, 2011 | 10:20 PM
I remember that. How did the little 4.8 like it?
No ****
Im looking at a cam that comes on early and hits hard.. Did you tune it yourself??
I was looking at the 220 and 224. I really dont want to go any higher on duration than that...
Old Jun 30, 2011 | 10:25 PM
MPFD's Avatar
I got my base tune from fastchip but I have had to dick with the idle alot till I got it right...
This was just after I dropped in the bench tune. (It would have idled much better if I would have taken it to him again) http://www.youtube.com/watch?v=QyIRI...eature=related It'w much better now.
If your gonna stay in the low 220-224 you'll be fine, Mine is 236/244.
