1.8 Yella Terra rocker ?s
Old Apr 18, 2012 | 08:07 PM
topher67's Avatar
Default 1.8 Yella Terra rocker ?s
First-I know all of you say rocker are a waste of time and just get a cam, but my funds are limited after the $2800 transmission rebuild
I just recently received a set of 1.8 yella terra rockers for $200 had to buy them.
stock cam 5.3L 2000 140,000 miles
intake lift .466 after 1.8 rocker .493
exhaust lift .457 after 1.8 rocker .484
2 questions
1-the stock springs are good to a .500 lift do I need to replace them? push rods?
2-I know the rockers need 22psi, but do they need adjusting?
Old Apr 19, 2012 | 07:23 AM
BigDaddy0381's Avatar
The springs should be fine and they shouldn't need adjusting after installed.
Old Apr 23, 2012 | 04:40 AM
sand man's Avatar
22ft.lbs yes , IDK about the springs but id get a cam while im at it, u can find used ones for cheap, ls6 ls2 are good and cheap with better lift
having those yella terras is like wearing CAT bots in your living room
kainzien
Nov 10, 2023 11:37 AM
gaps
Oct 15, 2015 02:53 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
redbird555
Sep 30, 2015 09:28 AM
tim wellington
Sep 29, 2015 10:17 PM
