.040 or .054 Headgasket thickness?
Old Dec 22, 2006 | 06:55 PM
  #31
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I dropped by the world products booth at PRI this year and immediately thought of you hehe -- they had a nice, trick stand showing off an exploded view long block 454 ci lsx motor...
I'd read some strangeness about having to spread silicon all over the water jacket rings to get it to seal (and the guy said it was in the instructions -- but was also for a 7 second n2o car). I didn't get why that would be necessary with o-rings and I guess it isn't.
Old Dec 22, 2006 | 07:31 PM
  #32
02sierraz71_5.3's Avatar
https://ls1tech.com/forums/showthrea...2&page=2&pp=20
thats what Im talkin about 900+NA they are spinning this stroker motor past 9k , they are rating the block at being able to handle 2000+ for FI apps
Old Dec 23, 2006 | 12:39 AM
  #33
Stoichiometric's Avatar
Do you guys have any opinions on the Cometic Phuzion gaskets? They have a similar stainless 0-ring around the cylinders. I think they are also between $200-300.
Old Dec 23, 2006 | 12:59 AM
  #34
parish8's Avatar
single digit dreamer
never heard of them. got a link? do they have them for the gen3?
Old Dec 23, 2006 | 01:34 AM
  #35
XLR8NSS's Avatar
Adkoonerstrator
I believe Kurt at Wheel to Wheel tested them and came to the conclusion they are junk.
Old Dec 23, 2006 | 10:24 AM
  #36
Here is a link, I am pretty sure they are available for gen3.
http://www.cometic.com/phuzion.aspx
Old Dec 23, 2006 | 10:30 AM
  #37
Do you remember what problem he had with them? The o-ring around the cylinder failing or coolant weeping? I have used Cometic mls gaskets with good luck, I had not even heard of the Phuzion gasket until yesterday.
Old Dec 23, 2006 | 10:33 AM
  #38
XLR8NSS's Avatar
Adkoonerstrator
I don't remember exactly but, I'm pretty sure they didn't hold up any better than the GM MLS gaskets. Seems he likes the GM MLS up to a point and then the SCE TITAN gaskests.
The info is over on Tech in the FI section I think. I'd find some links but, I gotta go. Do some searching in that section under the username 427 (Kurt's username).
Old Dec 23, 2006 | 10:34 AM
  #39
Cool, I'll check it out. Thanks
Old Dec 23, 2006 | 12:07 PM
  #40
Bill Reid's Avatar
I remember talking to the guys at ECS that tried them as well... junk.
Bill
zblee
Nov 11, 2015 12:41 AM
Tydriver
45
Oct 23, 2015 09:19 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
GMCtrk
Oct 5, 2015 11:18 AM
97_ek
Sep 23, 2015 09:16 PM
