00' 5.3 Rod bolt torq angle specs? 1st or 2nd design
Got a question before i put this thing together! On ls1howto's torq specs chart it list's a 1st and 2nd design on the rod bolt specs....it says both are
15 lb ft but on the final pass.....1st design is 60 degrees and 2nd is 75 degrees....just seeing if anyone can confirm which one a 00' 5.3 falls under!
