who carries a 175 t-stat for a 2016 truck
Old 12-28-2016, 06:21 PM
flyingfool's Avatar
Default who carries a 175 t-stat for a 2016 truck
i've been on numerous sites and am having a hard time to find a specific t-stat for my truck. they all look different and nothing seems to match up?
please help
Old 12-28-2016, 08:47 PM
FFDP's Avatar
Why would you need one?
Just curious is all.
There really is no need to run a cooler thermostat unless you are pushing some crazy HP and hot lapping the crap outta the thing. Many high HP car/trucks run fine at 190-195.
Old 12-28-2016, 11:57 PM
flyingfool's Avatar
this is really for more usable life from the driveline. the stock 210 is an emmisions part, not needed unless you like burning em up.
most issue is i plan on keeping the truck for 25 years so, anything over 185 degrees pretty much destroys engine seals and gaskets after 180,000 miles.
transmission will live longer by getting lower temp heat transfer from engine block .
i live in the desert so the cooler the better, and the more power the motor can make the better.
i do tow and do long mountain trail driving. what else you need....
now can you tell me who carries the part?
Old 12-29-2016, 07:50 AM
ZO6Ted's Avatar
Possibly Lingenfelter. I believe it was a 160 that came with my Whipple but I don't recall exactly may have been 180.
Old 12-29-2016, 05:50 PM
FFDP's Avatar
Just for reference my old sierra had 258k on it, stock engine, seals, stock 195 thermostat and didn't leak oil. To say that temps over 185 make seals go bad after high mileage is horse crap, the oil system temp means more to the seal condition.
Also in case you didn't know this before and many don't know this, the stock gauge also reads 210 on 07-13 NNBS and the K2XX trucks but the real coolant temp via the temp sensor and computer is 190-198 just about all the time. Hook up a scanner and see for yourself.
Old 12-29-2016, 06:28 PM
07Softail's Avatar
Better off putting an oil cooler on it if it doesn't have one or go to a larger one.
RT
Old 12-29-2016, 06:33 PM
91LT16SpeedFormula's Avatar
FFDP is correct on temp. I have a Edge tuner I use only for the monitors on it and the coolant temp is always in the 190s
Old 12-30-2016, 12:23 PM
Noah Burns's Avatar
I've got one in my garage I bought for my 2014, I'll sell it under whatever online retail is just to get it gone. It is brand new in original package.
Old 01-03-2017, 10:40 PM
62nalide's Avatar
Do you still have it?
Old 01-05-2017, 09:17 PM
Noah Burns's Avatar
yea it's in the garage now
