Whipple pulley size for a 5.3
Old 04-13-2019, 10:12 AM
85LSburb's Avatar
Default Whipple pulley size for a 5.3
I am wondering what pulley you guys with a 5.3 were sent in your whipple kit. From what I can find i have about the largest one. Mine is 4.5. My whipple supplied tune is massively rich over 40% throttle. I wondering it’s due to having such a massive pulley. Just wanted to see what size some of you guys were supplied. Thanks.
Old 04-27-2019, 09:50 PM
ZO6Ted's Avatar
4.375 on a 14
Old 04-27-2019, 09:53 PM
85LSburb's Avatar
Thanks. A guy in Florida also has that size. Fell like I got screwed on pulley sizes.
Old 04-28-2019, 12:38 PM
ZO6Ted's Avatar
Well just keep in mind there is more to be had. Looking at dyno graph mine picked up ~ 60 tq and ~ 40 hp around 4200 it appears after tune. That was where there was the most improvement. Also my scanner says 7.5 lbs.
Old 04-28-2019, 03:33 PM
85LSburb's Avatar
Did you change your map sensor? Mine kept the stock one and stops reading at 118kpa. Think it converts to 2-3 psi. Just flat lines tell the boost comes down. I will probably just keep what I have tell I get my heads and cam in. Did put a lengthy gap on a hemi single cab today so I will just have to live with my pie pan pulley tell them.
Old 04-29-2019, 10:46 AM
ZO6Ted's Avatar
I just googled a chart and that converts to 17psi so somethings off. Maybe your sensor is bad but Im no tuner so... I just installed my kit as it came with no mods whatsoever until a 1yr+ got a tune. Thats what I liked about the kit over the Mag. More boost and hp out of the box and no mods just turn on the key and burnout lol.
Old 04-29-2019, 11:19 AM
85LSburb's Avatar
I emailed whipple and they said all the 5.3 gen 3 blowers come with 4.5 and the older gen 2 came with 4.375. Feb 2018 is when they changed to the gen 3. I also googled the 118 and it said 17 but that’s absolute pressure and barometric pressure is around 14.8 so only reading 2-3 psi positive. I will get a 3 bar map sensor when I have it off for the heads. I may get a boost gauge and a afr wideband also. Need to fix the traction issues before I can add more power anyways.
Old 04-29-2019, 07:28 PM
ZO6Ted's Avatar
Well mine is 4.375 so...lol on them huh unless I'm gen 2 blower? Gen 5 engine but idk. As far as psi? Yep 17 I'm an idiot. Didn't even cross my mind what was I thinking? Traction issues, mine is my daily work truck and it's always loaded to 6k with me. It still will spin them 40 ft loaded in 2wd from idle but I don't drive it that way. If I want to go it's 4wd for sure.
Old 05-09-2019, 06:40 PM
85LSburb's Avatar
Ordered some vas traction bars so maybe it will hook a little bit better.
Old 05-17-2019, 11:57 PM
supercharged680's Avatar
We are running a 4.000 pulley on the 5.3's with no issues using 93 fuel.
Quick Reply: Whipple pulley size for a 5.3
