Oil stuck off
Issue been going on for awhile comes up as Po6dd code. Seems intermittent, DTC was on, made appointment at dealer- get there the light goes off, no code. On the way home 2 miles later DTC back on. Getting lousy gas mileage which I believe is a result of the valve/ solenoid being stuck off which causes the oil pump to go into high volume/ pressure mode. I'm about ready to get out of this truck into something slightly newer, like around 2018 with an 8 speed- what a rocket that must be with the 3.42 gears even if it's only with the L83. I read somewhere and wanted to ask and verify- were the oil pump solenoids/ valves upgraded/ updated like around 2017? Or is it still luck of the draw? Could having DOD tuned out have an impact on said solenoid becoming stuck?
TIA
TIA
