freon leak
Old Mar 30, 2015 | 09:22 AM
rumblebox's Avatar
Default freon leak
has anyone else developed a serious freon leak suddenly?
it started to get warm last week, & I noticed my a/c had stopped working. I recharged the system and added dye. three days later, it's empty again. I haven't searched for the leak yet, but I'm wondering if anyone else has had a similar problem and where the leak was.
Old Mar 30, 2015 | 10:59 AM
FFDP's Avatar
I thought I remember reading it was coming from the ac compressor or a hose going to it. Atleast thats what another person was saying, GM fixed it under waranty.
Old Mar 30, 2015 | 11:03 AM
rumblebox's Avatar
It's leaking from the joint between the condenser and dryer, which have to be purchased as a unit, which is also integrated with the trans cooler. Yay for expensive parts barely out of warranty.
Old Mar 30, 2015 | 08:50 PM
ZO6Ted's Avatar
Time to hit the salvage yards. car-part.com
Old Apr 12, 2015 | 04:07 PM
slovarado's Avatar
Registered User
Same thing happened to my truck at 10k, theres a recall or tsb on the high pressure line and the brackets, they had to replace the whole thing on mine. Happened the first day it was actually hot outside to. Bummer that you're out of warranty.. just make sure you get the updated line and brackets so it doesn't happen again
Old Apr 13, 2015 | 03:19 PM
colekill's Avatar
KickinAssAndTakinNames
36k miles already? that's bull **** if they don't cover that on warranty
im a little under a year and 30k miles now
Old Aug 19, 2016 | 04:16 PM
rumblebox's Avatar
So the leak recurred in the exact same spot at about 100k miles. Now I'm at 110k and have to add damn near 3 cans of freon a week, and nobody but the dealer has one available to order. **** that. I'll JB weld the bitch before i let my truck be the cash cow they indended again.
Old Aug 25, 2016 | 06:39 PM
Ryan Mills's Avatar
That might actually work.... Use an acid to clean/etch the aluminum and give it a shot.... I've had good luck with epoxy when I ran a drill bit through my damn $1000 radiator, mounting fans. The bit broke and I stabbed right into it. JB weld fixed it.
Old Aug 25, 2016 | 07:42 PM
Wolftrk99's Avatar
There is a local shop here that builds ac lines, etc that inhave used a few times to repair hard to find or outdated/obsolete parts.... Wondr if theres somewhere around you?
As far as your leak you should take it to a dealer and bitch, its a 14, you shouldnt have to put ac parts in it regardless of mileage, and if its a known problem theres probably a special policy or something on it..... Wouldnt hurt to check!
Old Aug 26, 2016 | 08:53 AM
ZO6Ted's Avatar
Get online and order from a salvage yard. Plenty of wrecked trucks!
