Cylinder #3 misfire with AC on
You'll have to pull the whole fuel rail and replace all the seals on all the injectors you pull.
So if it was me I would swap on the same side so you don't have to buy two packs of injector seal. So maybe 1 and 3 and see if it follows the injector.
Don't know if you've replaced the seals before since you bought your injectors new. But they are a B!%@#, ask me how I know.
Here is a really good how to video. And it was the only way I could get my injectors to seal.
https://youtu.be/htLtikGBjFA
I'm goIng to try moving the spark plug and then try moving the injector see what happens.
That's a good point. I didn't realize this is on a 2014+. So it's better to swap them on the same bank if it allows you to keep the other bank undisturbed, because you do need to replace all the lower seals if you take them out.
Correct the seals have to be replace anytime you remove it from the head.
Was told by a reputable shop that the plugs I am using are too cold and are causing the issues. They had the same issues with my current plugs. I tend to agree with them and am going to replace all of them to a hotter spark plug. Will update when done.
Did you do something to need cold plugs?
And how cold did you go?
I had this happen to me last year after switching plugs out. I have never had a NGK be funky in 20+ years using them on my cars and customer cars but last year I did plugs on my truck and it developed a #5 misfire. Plug looked perfect, ohmed out good, no cracks no nothing. But I swapped out that plug and it's been fine since, did a new set of wires too since the OE's had 130k on them. I did find carbon arc marks down the side of the plug though which showed the spark was jumping from the plug wire to the base of the plug along the porcelain rather than through the plug. Not sure why, but it did.
So I went to auto zone and bought 8 ngk LTR6IX-11 today and will switch them out. I will leave the gap alone as well until I'm ready to install supercharger then gap em down.
00pooterSS (05-27-2020)
I'm putting a lt4 supercharger on the truck. so when I installed the headers a couple weeks ago I figured I'd go ahead put new spark plugs in while I was there. I thought I had purchased one step colder ngk's LTR7IX-11. Also i gapped these to .030 for boost not thinking it would be long for supercharger to go on. Well anyways These are actually two steps colder and the gapping isn't great for a NA motor.
Inspect the plugs carefully for cracking in the porcelain. It's pretty easy to accidentally crack em. Especially with certain sockets. I have one I call the cracker. It's a sweet $50 magnetic spark plug sockets that holds the spark plugs/keeps them from falling out of the socket, but damn it's really easy to crack one using it.
