Christmas in May
#34
Annnnnddd Done!
#36
You don't mess around!
I was going to buy this right before I sold my truck...
Traxion Topside Overhead Creepers 3-100 - Free Shipping on Orders Over $99 at Summit Racing
#37
Pic with the ladder looks like you were taking a nap....
My boot prints are still on the wall in my buddys garage from my cam and spring swap...
i decided not to deflate my tires
#38
So I've realized my stregnth is with turning a wrench and not tuning. Black Bear is doing my tuning but I'm trying to get logs for him. I have my calc_pids set up for my wideband
as follows
# Units
# See sae_generic.txt for more information on the *UNITS section
*UNITS
#Code System Abbr Description
AFR1 NONE AFR "Air fuel Ratio"
# Add slot definitions here
# See sae_generic.txt for more information on "SLOT" formats
#Units Low High Fmt Expression
*CLC-00-0018
V 0.0 5.0 .1 "{EXT.AD1}"
AFR1 8.0 20.0 .1 "({EXT.AD1}*2.375)+7.3125)"
*PRN - Parameter Reference Numbers
# See sae_generic.txt for more information on the *PRN section
#Code PRN SLOT Units System Description
CALC.AFR_AEM F018 CLC-00-018 AFR 02-wide "AEM Wideband - Input 1"
In v7.5 scan I can see it under Pids (f8) and select it, but under data(f9) it still doen't show up. Justin gave me a .pid file to log with and I added that calc pid as follows, but it still doesn't work. I have verified by looking at the analog inputs on the V2 I can see the voltage moving around under AD1. Any advise or help?
[Parameters]
CALC_AFR_AEM=1,-1
CALC.FPS=1,-1
CALC.INJPWDC1=1,-1
CALC.POWER_RW=1,-1
GM.APP=1,-1
GM.ETCTP=1,-1
GM.HO2S11=1,-1
GM.HO2S21=1,-1
GM.INJPWB1=1,-1
GM.KR=1,-1
GM.MAFFREQ2=1,-1
GM.TRQDES=1,9311
GM.TRQTRANS=1,-1
SAE.ECT=1,-1
SAE.IAT=1,-1
SAE.LONGFT1=1,-1
SAE.LONGFT2=1,-1
SAE.MAF=1,-1
SAE.MAP=1,-1
SAE.RPM=1,-1
SAE.SPARKADV=1,-1
SAE.VSS=1,-1
as follows
# Units
*UNITS
*CLC-00-0018
[Parameters]
CALC_AFR_AEM=1,-1
CALC.FPS=1,-1
CALC.INJPWDC1=1,-1
CALC.POWER_RW=1,-1
GM.APP=1,-1
GM.ETCTP=1,-1
GM.HO2S11=1,-1
GM.HO2S21=1,-1
GM.INJPWB1=1,-1
GM.KR=1,-1
GM.MAFFREQ2=1,-1
GM.TRQDES=1,9311
GM.TRQTRANS=1,-1
SAE.ECT=1,-1
SAE.IAT=1,-1
SAE.LONGFT1=1,-1
SAE.LONGFT2=1,-1
SAE.MAF=1,-1
SAE.MAP=1,-1
SAE.RPM=1,-1
SAE.SPARKADV=1,-1
SAE.VSS=1,-1
#39
That ladder was all my brothers idea, it worked great. The install said 8-10 hours, Took us a little longer, but it was still an easy weekend job.
That looks awesome, I may have to add that to my wish list. Figure I need to buy all the tools I can now before the next woman comes into my life and I'm shut down
