8 Speed trans
#81
I think the exact opposite. My truck slips into gear every up shift when im cruising. It def firms up when im WOT but around town, it 100% still slips into gear like it did stock. My tuner said GM does this on purpose so the driver doesn't notice the shift. Funny we are talking about this because on my way into work i thought the next time i am at my tuners, im going to have him firm up the shifts when cruising. I think its annoying and feels lame when it slips into gear. Ive always liked the quicker and more firm shift. Somewhere between where it is now and the shift at wot would be good for me.
Atomic, did you ever play with the tcm I sent you?
Well I was riding with Sam as he tuned. All of my shifts are firmer now and he didn't adjust the shift firmness, he just reduced the timing drop between gears. I think you're feeling the timing drop, not slip. But I don't know I'm not there.
Sounds like you need a different tuner to tune your trans. Not all tunes are good tunes and not all adjustments are a one size fits all. Talk to your tuner and tell him what you want it to do or find a tuner that understands your desires better.
#82
I have a gauge for that
Sounds like he did it correctly. You dont want to fight the shift logic on these transmissions, you want to work with it. The controllers are great at what they do, tell it you want to shift faster and it will do whatever it needs to (increase pressure) to get the job done.
#83
Not yet, I havent really had time to mess with it yet. To be honest I like the way the truck shifts, I cant even tell its changing gears. I would think it would be super annoying if I could feel every single shift at light throttle. Having 8 speeds is a lot of shifting haha.
#84
#85
why would i need a new tuner. my truck shifts the same as yours and continues to slip into gear. exactly what atomic said. As for timing during shifts, I dont know, it pulls hard and shifts firm when wot, when im cruising its hard to feel the shift. Our trucks are shifting the same exact way but you said i need a new tuner? huh?
#86
These were WOT, however the best I can tell from talking to Sam and watching, the new transmissions shift a bit different. From what I gather, (and don't take my word as gods word) but I believe the old 4L's slipped into gear during shifts and the 6L and 8L just shift and cut timing during the shift to ease the feeling of the engagement. And that's my theory on why 4L60's sometimes wore out at pretty low mileage on vehicles that were driven grandma style. I always drove my 4L60's hard and the last two I had lasted to 190k and the other I sold with 190k still going strong. I talked to a trans builder and he agreed that the aggressive driving led to less slipping during shifts and made the clutches last longer. The trans I mentioned that went to 190k was in my camaro and it had a stall in it and sticky tires for the last 60k of it's life too.
A buddy of mine just got 230k out of a 6L80 in his work truck that weighs in right at 10k (2500 6.0 gas truck with stacked job boxes etc and is way over loaded) and had never serviced in it's whole life, not one fluid change or filter. So that also makes me think that the 6L's don't slip the shift.
Edit: also Sam said those times are from beginning of clutch release to full apply. So if they are shifting that fast, IMO there's no time for slip, it must be full off and immediately full on.
Are you sure that 2500 6.0 gas truck was a 6L80e? and not a 6L90E ?
Are you
#88
#89
Mine feels like a very well setup shift kit after the tune. No slipping, not harsh, doesn't bang into gear.
On mild acceleration you feel every gear clean and crisp and quick, but NOT jerky or harsh, tiny little bump like it should be, if you even call it a bump. It happens very quick and you feel it a little. Same at WOT it does it's thing fast and no slip and no neck breaking slams into any gear. Has a very noticeable firm engagement at WOT but never slams/bangs/chirps tires. It hits harder than stock though, in almost all situations, but never annoying, even for my wife with A LOT of disc issues in her neck. I asked if I could have it chirp on the shift and was told no, it'll just beat up the trans unnecessarily is what he said.
On mine if you hold your foot dead still and give it say 30-50 percent throttle.. when it goes to shift you feel it quickly stop pulling then all the sudden it pulls a little harder than it did in the previous gear because it went 100% engagement into the next gear and set in near peak torque so it has a bit of a pull each change in gear. It's far more noticeable on e85 since the timing is turned up more on that table. No slipping... Just quick precise changes with no slipping or banging. Because it isn't slipping and he didn't over do the reduction in timing drop.
I feel like I repeated myself a lot lol.
#90
There also could be a difference in the way we describe it. But I could tell majorly with my 4L60's when they slipped into gear and the slipping of the converter as they came up on the stall speed under light acceleration. This trans feels NOTHING like that.
I also logged the torque converter lockup, these trucks keep the lockup engaged at pretty much all times, except while idling or real low speeds. This trans feels like a standard, it always feels like there's 0% slip/just locked in gear with the clutch released. Which was confirmed when I saw it keeps the converter locked all the damn time.
