5.3 Cam Parts List
Front seal, timing cover seal, valve cover gaskets, water pump gaskets, crank bolt
Not 100% sure on the gen5. But those are the basics. With it being a 2015, I suppose you could change the timing chain, cam gear if you wanted but it might be ok.
Gen V Crank Bolt yes, front cover has silicone, valve cover gaskets are o ring, water pump has silicone, go ahead and do pushrods, lifters, chain will be good and springs if the cam specs them.
RT
RT
fix-it man
13
Nov 23, 2012 09:24 PM
lt4malibu
Sep 26, 2011 08:36 PM
