2014 sierra tru cool
Old Feb 28, 2016 | 10:53 AM
Carlos_sierra's Avatar
Default 2014 sierra tru cool
Does anyone have any pics of how they installed an aftermarket tranny cooler. Just need to get an idea of it
Old Mar 10, 2016 | 02:06 PM
rudvirus's Avatar
Here you go https://www.performancetrucks.net/fo...rdware-508374/
Old Sep 1, 2016 | 09:09 PM
silverado.408's Avatar
Bump this to the top. Any more info on this??
Old Oct 27, 2016 | 10:20 PM
Chalino Sanchez's Avatar
You need to remove the temperature thermostat in the tranny block or buy a 6l80e manifold block ,if you dont remove the thermostat ,no matter what you do thermostat with dictate temp 190+. From tranny to radiator in /out to 40kcooler back to tranny. Or bypass radiator. Im working on doing writing up.
Old Oct 30, 2016 | 08:13 PM
07Softail's Avatar
you don't need this cooler, all you need to do is remove the thermal bypass valve plug the hole and your good. My trans doesn't run any hotter than 160 running the crap out of my truck with a converter.
RT
Old Nov 2, 2016 | 10:16 AM
Boost-freak's Avatar
RT
post a pic if you don't mind
Old Nov 2, 2016 | 08:54 PM
07Softail's Avatar
Default thermal bypass removal
I did this at my Fathers house with a Brace and Bit and a chainsaw so no giggling! as you can see the t stat and the spring is removed and i tossed them in bag, did some measuring and came up with a stainless button head screw and that is the seat end and filed the end of the screw to get the correct length. The bypass uses the spring to keep the t stat off of the seat and when temp rises the t stat brass end makes contact with the seat inside of the aluminium block mounted on the transmission and lets fluid run through the cooler. Basically my valve stays seated and lets fluid pass through the cooler all of the time. BTW you really don't need to turn the treads off of the screw at all just file to length. Questions just ask
RT
Old Nov 3, 2016 | 03:45 AM
thanks bud i will look into it
Old Dec 18, 2016 | 05:30 PM
flyingfool's Avatar
where is this located on my truck?
Old Dec 18, 2016 | 06:35 PM
07Softail's Avatar
The T-stat block is bolted to the bellhousing on the driver side, remove the lines and then the 10mm bolt and then the block can be removed,
RT
